sglynn
What is the range of the elevator trim tab suppose to be on the 7A? I see the manual says 25-35 in the Maximum Up/Down column but is there just a max? Is there a minimum? The chart is blank for minimums. How many degrees do others get on their trim tab. Mine goes up 22 degrees and down 23 degrees for a total range of 45 degrees. In this case up means the trim tab moves up, not the nose of the airplane.
I'm getting close to first flight and double checking everything.
thanks
thanks
