Hi all. I have an IO 360 (350 hrs) that started backfiring at idle when warm. I went through those threads. i saw a little fuel/oil on the inlet manifold of number 2 cylinder so took it for an engine run to see if i could see anything about that cylinder.
Once warm at idle it began back firing again. But after about 30 seconds the backfiring stopped and the EGT and CHT of number 4 cylinder dropped away and the backfire stopped. So at least i think i can isolate the backfiring to number 4 cylinder because it stopped when the cylinder stopped.
Any thoughts on the most likely problem? Blocked injector? Stuck valves?
Help appreciated.
Help appreciated.
