Old 12-26-2017, 09:05 PM
Hornet2008 Hornet2008 is offline
Default Slip/skid ball
On the ground with the aircraft level(RV 9) my ball is half a ball out to the left. Should I shim it? I have the ADRHRS in its own shelf high behind the baggage bulkhead. All the best for the New Year and hope all had a great Christmas.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying
Old 12-27-2017, 12:06 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Shim it
I had the same issue, my ADHRS mount was not a level as I thought...
Make sure the fuselage is level across the cockpit rails and shim the ADHRS to get the ball centered.
If you don't level it the autopilot won't work well if it's drive by the EFIS.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-27-2017, 02:26 AM
Thanks Gil
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying
Old 12-27-2017, 07:09 AM
N941WR's Avatar
N941WR N941WR is offline
Check your ADHRS manual. You may be able to adjust with software.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-27-2017, 09:36 AM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
Make sure you don't have a flat tire!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 12-27-2017, 02:05 PM
az_gila's Avatar
Smile
Unfortunately not with the Skyview.
The ADHRS mount I'm presently making for my -10 will have the unit mounted on brass crews with nuts on each side of the mounting plate that can be used for adjustment. Adjusting shims while being halfway down the tailcone is a pain in many locations of your body.
Gil Alexander
Old 12-27-2017, 02:12 PM
snopercod's Avatar
The ADHRS mount I'm presently making for my -10 will have the unit mounted on brass screws with nuts on each side...
Nylon hardware is another option.
(2018 dues paid)
Old 12-27-2017, 03:21 PM
Default Unfortunately mine is a Skyview
Yes I looked through the manual. Not flying as yet, aiming for end January.
Thanks for all your help. Happy New Year. I'll be watching the fireworks on Sydney Harbour.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying
