rvator51
Katie's RV-4 O-320 went over 2000 hrs SMOH so we started looking for a replacement O-320 for it. Got a great deal on a new overhauled O-360 instead from a fellow VAFer in June. We figured it would take 1-2 months for the conversion. Instead, it took 6 months. We ended up replacing the lower firewall and then everything firewall forward. The old cowl from the 80s wouldnt fit the O-360 so we had to do a new cowl too.
First flight was New Years Day. Everything went great. Interesting that the RV-4 now flies a couple of degrees higher in the tail than before. The O-360 is noticably faster than the O-320 we had. I flew it with the wheel pants, gear leg fairings and intersection fairings off to help keep the speed down. At 2600 RPM it was doing 192 TAS and 200 mph TAS at 2700 RPM. Katie is going to love that!
After landing, we removed the cowl to check for any problems, leaks, rubbing, etc. Found a few drips of oil on the air box.
