Same result; took a Sensenich Aluminum fixed pitch off the wife's O-320 powered RV-4, Installed the Sensenich ground adjustable carbon fiber prop, set to pitch position 5. she attained 190 TAS@ 2700 RPM 4 MPH faster than the previous prop, and she climbed out of the airport @ 2000 FPM which out climbed the previous prop. so although the numbers might not be cast in stone, they are a direct comparison on one airframe, engine & instrument set. Other planes may be faster, or more effort spent on documenting performance.
Marilyn is pleased.
I have a CATTO on my RV-8, which I am also very happy with. You need to work with Craig to nail down your engine power & Flying style/expectations, so he can build your prop. He met my goals.
