Old 06-21-2018, 03:50 PM
istrumit's Avatar
istrumit istrumit is offline
Default CHT issue or not ?
Hello all
Starting about 10 hours ago, I have CHT on number 5 (IO-540) running about 20-25 degF hotter than #6. They used to be nearly the same. So #5 is running 390-400, while #6 is running 370-380.
This is at full manifold pressure and leaned. And at full gross, in summer time.
There is not variance to mention in EGT.
My reading indicates this is not necessarily anything be concerned about.
But what say VAF ?
Scott
Scott Martin
N430WP RV-10 - Purchased
Old 06-21-2018, 04:17 PM
jrs14855 jrs14855 is offline
Default CHT
Swap the leads and probes and verify that its not an indication problem. Most of the experts say that 400 is ok AFTER the piston rings are seated.
Old 06-21-2018, 07:20 PM
istrumit's Avatar
Mostly I am wondering about the recent change in behavior (+25 degrees) relative to #6.
Scott Martin
Old 06-24-2018, 10:24 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Try this first to get a better understanding as to weather there has been a real change or if its an instrument error.
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 06-24-2018, 06:30 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
+1 on this advice. Also, you might want to think about cleaning fuel injectors. I had a similar problem with sporadic CHTs last summer. Cleaned fuel injectors and problem solved.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 06-25-2018, 04:49 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
What does this mean? Leaned how much? were you still ROP or LOP? Is this at top of climb and what IAS are you climbing at.
Review your EMS data file to see if what you think you are seeing is actually pound for pound what is happening.
As a reference when WOT/2400/LOP in summer, I will see CHT's in the 320-355dF range. In the cruise.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-04-2018, 10:11 AM
istrumit's Avatar
So, I suspected that magneto (I have lightspeed on the other side) timing had advanced and was causing CHT issues over all (not just on #5).
When I took it for an adjustment, I also took off the plenum, just to see if there was anything obvious causing #5 to run a little hot.
Yup, the beginnings of a birds nest. Straw covering the front and back fins of #3 and #5.
Problem solved.
I also got the timing checked and it was a bit off...so, all good. !
Scott Martin
