Old 06-24-2018, 02:33 PM
Sam Staton Sam Staton is offline
Question Convert dual mag to single mag
My engine is a 6D version - single drive, dual mag. I am curious if anyone knows of a conversion kit that will replace the dual mag with a single. Since I already have electronic ignition, I donít need two. Sort of having second thoughts about an all-electric airplane. I know it sounds like belt & suspenders, but I think maybe I might feel better if I have at least one dinosaur mag on board. Replacing the accessory case is a non-starter.
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Hartzell C/S
Dynon SV1000 & SV700
Old 06-24-2018, 03:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Perhaps a call to Knots2U may be in order. My highlight below.
This is on their web site for ElectroAir certified ignition stuff.
16. My engine has a dual magneto, how do I adapt my engine to use the EIS?
EXPERIMENTAL ONLY! We use a split ring collar on the crank shaft for the electronic ignition timing pick-up. There are some single magnetos that will adapt to the dual mag hole, or alternatively you can operate two electronic ignition systems. Call us and weíll review the details.
http://www.knots2u.net/electronic-ig...ent-eis-41000/
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2018, 05:20 PM
Hi Sam!---Gil has some good data on this!
Tom
Ridgeland, SC
Old 06-25-2018, 04:03 PM
brooksrv6 brooksrv6 is offline
I had bought a bendix single mag converted to the Dual mag drive from AeroSport Power. I'm unsure of the parts actually changed.
Chris
Old 06-25-2018, 06:08 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Default It's all in the archives
If you're willing to dig into this very forum, you can find part numbers of all the parts required. In a nutshell, there is (1) Bendix mag that works, but you have to transfer the original Dual-Mag impulse coupling/gear to the new Bendix (single) mag.
