Old 09-24-2018, 01:48 PM
Machsandy Machsandy is offline
Default Step bolt access
We have a wee bit of play on our left step and I believe this may ba a common issue.
How do people access the bolt to replace or bush on a completed aeroplane?
Old 09-24-2018, 03:02 PM
I intentionally cut 3/4" or thereabouts holes in the floorboards and belly of the airplane in anticipation of this issue. Snap plugs close the holes and my trusted factory resource saw no challenge with that approach.
Should be an easy mod to retrofit if you can get measurements for where to drill. I'd measure mine, but am out of town for a few days.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-24-2018, 04:49 PM
Thanks Kyle that sounds a very sensible approach. Sadly, I am guessing that here in the UK that would require a modification approval from our regulator, the Light Aircraft Association?
However it may be an option?
Old 09-24-2018, 04:57 PM
Not that I'm a big rule breaker, but that one wouldn't exactly jump out at most inspectors.
Where are you in England, out of curiosity? I'm posting from London right now.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-24-2018, 06:00 PM
mciaglia mciaglia is offline
Itís actually described in the instructions as a way for access. So you might not need any additional inspections.
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 09-26-2018, 08:43 PM
ScottCC ScottCC is offline
Default step wobble
I'm about to install my floor panels and heard about this happening. I ordered (and received quickly) 2 "step bushings" from TCW Technologies. A friend of mine installed them and says they're great. He also installed an access panel in the floor and a small hole under the fuselage, to access later if needed to tighten. I plan to do the same.
Scott Calkins
Building RV-10
Working on section 33 - Baggage Area
Dues happily paid 2018
Old 09-27-2018, 04:33 AM
leok leok is offline
Default Floor Panel
I added a small floor panel over the bolt.
It gives access for install/tightening of the step bolts as well as the com antenna installed in the same left and right bays.
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 09-27-2018, 12:31 PM
lr172 lr172 is offline
I did the same with a opening large enough to get both wrenches in there. I used quite a few CS pull rivets, so it should easily hold the loads placed on the floor with cargo.
N64LR
RV-10 in progress
Old 09-29-2018, 12:12 AM
WrightsRV7 WrightsRV7 is offline
Default inspection panel parts VA-195C/D
I used one inspection panel supplied in the kit since I did not install the wing stall-warning indicator. They are cheap and easy to install in the baggage area with lots of room for wrenches, and can all be done with solid rivets and squeezer (nothing against CS rivets, but solid if I can). Also is great access to the area for wiring too, like an ELT antenna or......... Always good just in case you do need to do something in that area, great your looking ahead!
Cheers, Mike
Michael Wright
Dues paid 2018
RV7 built & sold, 500h of pure joy in the air: sold
RV10 slow build, 200+ hours in the air
Old 09-29-2018, 12:25 AM
Cheers, Mike
I figure the Engineering is solid. The whole baggage floor is held on with pull rivets, so I assumed they were adequate for the load back there.
N64LR
RV-10 in progress
