I have a quick build RV-8 and I just mounted one of my flaps the other day and was wondering if the inboard end of the flap was suppose to be bent at a 90 degree angle like the rest the the flap leading edge is, so it increases the strength and doesn't interfere with the wing rear spar? As it is now the inboard leading edge hits the rear spar/flap brace in the full retracted(Up) position. If not should I trim some of the inboard leading edge off, so it doesn't rest up against the rear spar/flap brace?
