flap spar dimpling
which dimple method/mechanism
Ray
It depends on what you are using to dimple.
The DRDT-2 has a documented limit of 0.040. When I dimpled at that thickness I believe I also did slightly additional debur to shave enough for flushness when I drop in a rivet.
Beyond this I believe you would machine countersink.
Cheers.
Michael B.
Counter sink them. If you dimple you will still have to do some counter sinking because the spar is thick enough that you won't get the skin to nestle in the dimple properly.
When building, remember that hundreds / thousands of RV's have been built as described in the plans.
Good luck!
