comfortcat
OK, I'm not talking about paint, but anything with the word "prime" in it seems to start a war.
I'm building my O-320 Carb engine primer and plan on two cylinders. I am using the electric valve and I bought a pair of AN4022-1 discharge nipples from Aircraft Spruce.
BUT
Instead of seeing a AN type male fitting, I'm seeing a cup in the top of the discharge nipples. OK, what do I need to attach that? I'd like to use as short a copper line as possible, and maybe a flex hose from the primer valve to a t-fitting on the top of the engine. Can I get flex hose with a 2d fitting?
Thoughts?
Dkb
BUT
Thoughts?
Dkb
