rightrudder
I want to avoid the stainless vs. plastic lines debate, but if one were to go with plastic lines, what sort of fitting is needed to connect the firewall-mounted AN4 flare fittings to the plastic lines? I'm not sure I saw anything in the bazillion bags of hardware that would work.
Also, the plans picture a much thicker line going from these fittings to the master cylinder, and I didn't see this anywhere in the kit...so is it accepted practice to use the same plastic tubing that's used from the reservoir to the master cylinder?
