Old 09-28-2009, 08:01 AM
DanH's Avatar
DanH DanH is offline
Ok, previously we looked at simple ducts. It is also possible to build assemblies of moderate complication with simple foam block male forms.
This is the start of a filtered airbox. The idea was to package the maximum possible filter media area into the limited volume forward of an AF servo (standard cowl without a prop extension).
Here's the basic form. Sometimes a section of a form requires more detail than you can easily shape in foam, or the shape of the detail is critical. In this case the box needed a careful bellmouth radius at the servo entry. A few minutes on the lathe resulted in a nylon block form with the required shape, which was then grafted to the foam block. Epoxy will not stick to waxed nylon.
The interior of the box needed "rails" to constrain the filter. The key here is to realize the form is really a mirror image of the inside of the finished part; cutting into the block results in a protrusion later. In this case I simply fired up a router and cut slots in the block. The inside of the slots are skim-coated with epoxy to seal the foam, just like the rest of the form, and get the same wax and PVA treatment before layup.
The basic layup to form the box is conventional. In this case there is one addition. The slots were spooned full of epoxy/flox mix and squeegeed off flush with the surface of the form. Then the shell layups were applied while the flox was still wet. This "wet-on-wet" method makes the filter rails integral with the shell; no bonding issue.
The box needs to come apart for filter maintenance. When cured the shell was cut into two sections without removing the foam core. All it takes is a fine cutting wheel on a Dremel tool. The cut is just inside one of the rails, which you can easily see through the glass shell.
Next step is an overlapping flange to seal and attach the two halves. One half of the box got a layer of slick packing tape to form a no-stick surface (a bit of vinyl electrical tape covered the corners where packing tape wouldn't lay down neatly). The other half of the box was scuffed for bond prep. Three plies of glass were impregnated between plastic sheets. The flange shape was drawn right on the plastic, then cut to size with a rotary knife (the "pizza cutter"). Peel the plastic off one side, place the bulk layup, peel the other side, and stipple with a brush to remove air.
When cured, dig out the foam. The wax and PVA coated epoxy "skin" placed on the foam form earlier will peel off the inside of the parts like a bad sunburn. A few sharp raps with a rubber hammer, a bit of compressed air blown under the flanges, and the two sections pop apart. Here we are after a bit of rough trim....
....and with the filter inserted on one half. Part number is K&N 33-2124
Continued next post.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-28-2009, 08:10 AM
AX-O's Avatar
AX-O AX-O is offline
Very nice Dan.
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 09-28-2009, 08:24 AM
DanH's Avatar
One detail neglected in the previous post was a method of attaching the two halves together. If you look close you'll find ordinary #6 nutplates imbedded in the layup. They were simply pressed into the wet flox prior to the shell layup. They're visible through the glass, so later I'll cut a little hole for the screw, clean 'em with a tap, whatever. If I was really picky about the threads I could have filled them with clay or wax. BTW, the formed-in-place flange is almost airtight without screws.
Anyway, here's a trial assembly of the box, with filter. Filter media area is roughly 2X more than a Vans snorkel filter.
The flat area on top of the box gets an alternate air door, a project for a few evenings this week. Then I'll send it over to Don at Airflow Performance for a check on filter pressure drop. Fine example of why 90% of us leap up like an SEC football crowd and start chanting "Airflow, Airflow, AIRFLOW...." when somebody starts an "AFP vs Precision" thread <g>
When it gets back from South Carolina I'll do the usual surface finishing and make it pretty.
POSTSCRIPT: Filter loss (loss in air pressure with the airbox assembly installed on an FM200 throttle body, as compared to a "perfect" test bell mouth intake on the same FM200) was 1.9" H2O, or 0.14" Hg. That's about the same as a butterfly valve in a bare tube.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-30-2009, 09:59 AM
DarylT's Avatar
DarylT DarylT is offline
Default The Master
Is Dan the master of fiberglass or what?
I bet he has furniture made of the stuff.
Thanks for the great tips Dan!
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2019
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
824 hours and climbing
6th Condition Inspection complete 10/31/2018
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 10-04-2009, 02:34 PM
DanH's Avatar
Here's the alternate air door, 5 x 2.25, plenty of area. The hole was cut in the top of the box and the inside perimeter of the hole was painted with PVA. Three plies of 9 oz was saturated with epoxy between plastic sheets, then cut to the desired size by marking right on the plastic and slicing with the rotary knife. Peel one side, carefully place in the box, peel the other side and stipple with a cheap acid brush.
When cured, it was popped out, trimmed, roughed up on the back side, and laid back in the box after washing out the PVA residue. A length of .125" music wire was bent to shape and holes drilled for the hinge points. The music wire was floxed to the back of the door and while wet one ply of 9oz was placed as a cover sheet.
With the flox cured, one end of the wire got a stainless washer as a thrust button and another small washer soldered on for a stop. The other end got the same stainless washer, a 1" long 4130 arm, and a stub axle with a sleeve and stop, again all soldered. The spring was sized and stretched so the door will open at about 2" water differential pressure. (Later note; on the flow bench it opened at 3"...close enough. It does disturb airflow slightly in its airflow-driven "'floating" position; you can tell from the fuel flow. If fully opened manually, it has no significant effect on airflow or fuel flow. I could switch to manual operation, but probably won't, as I like its instant, fully automatic operation with a blocked filter. The HP loss shouldn't be critical....we'll see.)
The arm is arranged so as the door opens, the required pressure becomes less and less with increasing door angle. The door stops in contact with the backside of the filter and will self-close.
So much for small parts made over foam cores. It ain't rocket science; jump in there and make what you want. Your airplane should include at least one totally custom part good for a satisfied grin when you think about it
POSTSCRIPT October 2011 The 1" long 4130 arm soldered to the end of the piano wire hinge didn't work out. The solder joint failed twice; too much torque. It was replaced with a one-piece hinge and arm all bent from a single length of piano wire.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-05-2009, 01:06 PM
algrajek algrajek is offline
Dan:
Is this FAB for a 0-360 cowl with the snorkel or a flat bottom cowl with "S" duct?
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
Old 10-05-2009, 01:13 PM
Jkkinz's Avatar
Jkkinz Jkkinz is offline
Hey Dan,
Maybe it is just the angle of the picture but the swing arm and the spring look like they are almost in line with each other when the door is wide open. I would think that that much swing in the arm might allow the arm to go over center and have the spring hold the door open. Just an observation : )
Jim Kinsey
7A Finishing and Engine
AFS screens
IO360A1A, Catto 3 blade
N527K reserved
Donated thru 2018
Old 10-05-2009, 01:47 PM
DanH's Avatar
Originally Posted by algrajek View Post
Dan:
IO-390 with a one-off intake under the spinner.
Originally Posted by Jkkinz View Post
......the swing arm and the spring look like they are almost in line with each other when the door is wide open. I would think that much swing in the arm might allow the arm to go over center and have the spring hold the door open.
Almost is the operative word. The door is firmly against the back side of the filter at the "almost" position.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-31-2009, 01:16 PM
DanH's Avatar
Finished product. Process was the usual; epoxy/micro to fill then 80 grit sanding, shell w/epoxy for scratches/pinholes then 180 grit sanding. Primer and two-part single stage color seems to cover 180 grit sanding ok. The exterior cowl surface got primer and K36 sanded to 400 grit as it will later get a two-part pearl topcoat.
That's all folks.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-31-2009, 01:25 PM
Lookin seriously good.
