Old 03-09-2019, 03:25 PM
Subwaybob's Avatar
Subwaybob Subwaybob is offline
Default Delete from order / Buy extra stuff RV-10
Little help on the 10 order please. Searched all the post that I can. Here's my list. If you can think of anything else that's cool to add or where to buy some of the (?) items please let me know.
Air frame:
Aero LED Lights
Duck Works Light install kit
Avery tools rudder cable fairing
Bonaco or TS brake and fuel lines.
Extra NACA vents for rear
Matco Brakes, maybe wheels?
Pitot sump bottle?
Interior:
Aerosport or Hendricks door latch
Andair Fuel selector
Glare Shield
Heavy duty door strut
Mcmaster Door seals
Mountain High Oxygen system
Soundproofing (How thick?)
Sun visor (Who?)
Aerosport arm rest with throttle quadrant
Aerosport overhead console
Aerosport Panel
Aerosport interior panels.
Aerosport baggage door
Aerosport carpet
Aerosport Seats?
Aerosport etc..
Rudder pedal extensions
Engine:
Airflow Performance for engine
Airflow Performance Fuel Pump
Emag Pmag
Louvers or cowl flap
Oil Cooler (Not Vans?)
Skybolt cowl fasteners
Thunderbolt Engine
MT 3 Blade prop
Vetterman Exhaust?
Instruments:
Vertical Power VP-X Pro
GTN 750
Dual G3X Touch
Garmin GMC 507
3 Axis Trim
etc… (Pretty much have this worked out)
Extra parts:
Leg fairing hinge pins
Extra angle and sheet metal .032?
excess nutplates, rivets, bolts all sizes
Bob
RV-10 QB on the way
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
Old 03-09-2019, 04:04 PM
I think if you get the matco brakes, you'll be disappointed without the wheels. Their setup (at least the version I have) is very different than Cleveland brakes, and the parts are not interchangeable.
What are the perceived advantages of the Vetterman exhaust vs the standard version? FYI, I just installed the standard system a couple of weeks ago and had no complaints.
Pacific Oil Cooler has a "near" drop in cooler that gives a fair amount more cooling capacity than the stock setup. I was disappointed that it wasn't an exact drop-in, which was what they had indicated. FYI, the mount holes on the -10 are closer together vertically by 1/16" than the slots on the mount ears for the oil cooler. That means the normal mounting hardware won't quite fit, even after you relieve the holes in the cooler mounting flanges. I used hex head screws and had to grind a flat on edge of the washers to make it work.
Having used hinges along the horizontal seams along the cowling sides on my RV-6 and screws across the top and bottom, I used hinges in the same places on the -10 but substituted skybolts for the screws. If I got a do-over, I'd use screws again.
I'm not a fan of investing the time, cost, and weight for braided lines other than firewall forward, but that's a personal decision. Making the aluminum lines is pretty easy.
What does an aftermarket glare shield do for you that a can of semi-gloss rattle can paint won't? Just curious.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-09-2019, 05:02 PM
Subwaybob's Avatar
I have the vetterman on my seven and it works well. I''l have to check the cost vs vans.
I like pre-made lines because they plug and play. No issues.
I am getting a full interior so paint on top of metal inside is not a choice I would make. It was fine for my seven but not the 10. I am going to do my best to make it quiet, VERY comfortable, and IFR super capable.
Bob
RV-10 QB on the way
Old 03-09-2019, 09:17 PM
DRMA DRMA is offline
My RV-10 came from Van's with a Vetterman exhaust system in the kit. Received it a couple of years ago as part of the FWF kit.
I think you want the Plane Around 180 door latch system. The outside door handle from AeroSport.
Have you considered Air Conditioning? If so, suggest you take a look at Airflow Systems unit.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 03-10-2019, 12:30 AM
paul330 paul330 is offline
As far as I am aware, the VANS exhaust is from Vetterman.
I'd definitely consider some sort of upgrade path for the brakes.
Pmag? Still not in manufacture but may be by the time you get that far - mind you, I was told that 5 years ago......
I would definitely get a supply of extra hardware such as the most used bolts (-4,-5,-6,-7,-10), washers, nuts, nutplates, #6 and #8 screws, rivets etc. Not expensive and I guarantee you will need them and find that you don't have them just when you need them. VANS supply "enough" but no spares to cater for loss or damage.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 03-10-2019, 04:27 AM
AviatorJ AviatorJ is offline
For tires I went with the dresser retreads along with the match brakes.
Sound proofing don’t remember the type but I used 1/2 inch thickness.
For sun visors I mounted a set of Rosens made for Cessna 310/340’s.
The exhaust you get from Vans is from vetterman. I would also maybe suggest working the add/deletes on a per kit basis. There are a lot of options out there.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 03-10-2019, 06:27 AM
ctennis ctennis is offline
I'd recommend step bushings from http://www.tcwtech.com.
Also recommend the Vans ADAHRS tray and the side shelf for ELT/Whelen mount. Much easier to install WHILE building the tailcone than after the fact.
N29213 - RV8 completed 2017
RV10 - tail and fuse *done*, wing and finish in progress
Columbus, IN - KBAK
Old 03-10-2019, 08:03 AM
Default Pmag?
hahahahahahahahahahahahaha...
Been waiting for that almost a decade!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 03-10-2019, 08:47 AM
rongawer rongawer is offline
Default Avoiding magnetos, PMAG or otherwise
For Matco wheels, don't forget to get their axles and spacers too and then delete wheels, brakes and axles from the kit. It's a very nice setup and I like 'em.
Why not just go with an EFII setup? It's not much more than a mechanical fuel injection system and certainly less hassle than magnetos...and, bonus tip, you can buy one right now {think SDS}.
Although it's always great to continue to discuss these topics, you might also look at the many previous threads on the topic too.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 03-10-2019, 10:46 AM
Subwaybob's Avatar
I just spoke to him. Suppose to be ready in about a month. So sometime in April/May. He said a lot of new engineering went into these and they will be available for certified as well, hence the delay. So get ready....
Bob
RV-10 QB on the way
