Old 03-08-2019, 07:31 AM
Plummit's Avatar
Plummit Plummit is offline
Default Mag timing on IO-540
I just had my mags (Bendix 1200 series) overhauled by Aero Accessories in
Van Nuys, CA. Installing them last night, I was unable to get the right mag timed perfectly due to it hitting the standby Alternator. I need to be able to move it a tad more up to get it to sync with the left mag at 25 BTDC. Anyone run into this? I'll call the mag shop when they open but thought I'd throw it out there for now.
-Marc
N814RV
2019 Donation Made
Old 03-08-2019, 07:32 AM
Carl Froehlich's Avatar
Take the mag out, turn the gear a little in the direction you need, reinstall the mag and time.
Old 03-08-2019, 07:41 AM
Plummit's Avatar
Bendix mags go into a slot, not a toothed gear. I'm not sure how to clock it differently, other than 180 out.
-Marc
N814RV
2019 Donation Made
Old 03-08-2019, 08:09 AM
Sorry - brain fart.
Old 03-08-2019, 08:19 AM
rocketbob's Avatar
rocketbob rocketbob is offline
If you have the tool to hold the distributor gear on the red mark, you can turn the gear another tooth and put the holder tool back in to get the mag to clock differently in relation to the stud holding it onto the engine.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 03-08-2019, 08:28 AM
Toobuilder's Avatar
The drive gear in the case can also be re indexed to get the slot where you need it. It should pull out fairly easily, but be cautious about dropping the bearing into the sump.
Michael Robinson
______________
Harmon Rocket II -SDS EFI - Flying
RV-8 - Flying
Old 03-08-2019, 08:30 AM
lr172 lr172 is offline
-Marc
The slot is in a sub-component that has a gear on the other end of it. It has a pilot bearing loosely holding it into the case. Pull that assembly out and clock that slotted sub-assembly. Be sure to use the pin in the mag when installing.
N64LR
RV-10 in progress
Old 03-08-2019, 05:29 PM
Super Moderator
You've already got great advice here. The gear assembly can be pulled out and turned. However, pull out the rubber cushions first so you don't drop them into the crankcase.
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
Old 03-08-2019, 05:36 PM
N319BC N319BC is offline
Vic
Absolutely, I learned the hard way. Not an enjoyable experience.
john
Old 03-08-2019, 10:35 PM
Plummit's Avatar
Default Update
I was able to get the mags really close but I want exact. It will get us to the Ice Cream Social tomorrow, but the next time I have the cowl off I will index the mag drive around to be able to get the right mag perfect.
Thanks everyone for your advice! I'll find out the details and post an update when I get 'er done!
-Marc
N814RV
2019 Donation Made
