Old 09-26-2013, 07:25 AM
blahphish's Avatar
blahphish blahphish is offline
Originally Posted by bkthomps View Post
so did you see a speed increase with the straighter pointing nose wheel?
I wish I would have tested to find out. Going to have to wait until after its painted, and at that point its not really a great test anymore. Unfortunately, I took it right to the painter after the adjustment on a quick 15 minute flight and didnt check.
Brian Unrein
RV10 N42BU 700+ hours!
First flight 6-16-12
http://N42BU.com
Old 03-06-2019, 10:13 AM
jwilbur jwilbur is offline
Default Old thread, new shimmy.
Resurrecting an old thread here.
I've been flying for about 1.5 years and have *never had a nose wheel shimmy problem. This morning I landed in some moderate cross-wind conditions and the landing was a little sloppy, coming down onto the nose-wheel quickly after the main gear. And there was a shimmy during roll out. The shimmy remained until I turned off the runway.
Several months ago I noticed the same thing. As I recall, that time was something like 10 gusting to 20 all crosswind and I had the same issue. I quickly put the nose wheel down after landing an the nose shimmied during roll out until turn off.
I fly about once a week and apart from these two incidents my nose wheel does not shimmy.
Anyone have any idea what might be going on here?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 03-06-2019, 10:39 AM
Have you checked the break out force on the nose wheel? I believe itís very common for it to loosen up, especially during the first year of flying.
Old 03-06-2019, 11:11 AM
It had loosened up but I reset it according to the plans at my annual last August. Both incidence of my shimmy were after this.
Phase II - 11/2017
RV-10 Build Log
Old 03-06-2019, 11:24 AM
N42AH's Avatar
N42AH N42AH is offline
Default Anti-Splat Nose Wheel Job
When I acquired my RV-10 almost 3 years ago I also had nose wheel shimmy. As a previous owner of an RV-9A and having done the Anti-Splat nose wheel and main wheel mods, I am a believer in the mod.
I sent my My RV-10 nose wheel off and had the mod performed. Once returned and installed I have NO nose wheel shimmy problems.
Now if there was only enough demand for Allen to be able to tool up to do the mains on an RV-10 I would ecstatic. Until then I still have main gear shimmy issues no matter what I do.
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/ N1FLY
Old 03-06-2019, 11:32 AM
In my case, I've only had a shimmy twice and both times after I let the nose down too fast during a cross-wind landing. And then it doesn't seem to stop until I get very slow and turn off the runway. I'm wondering if it gets triggered by a side load or something like that when it hits the ground. ... By the way, I have the Berringer nose wheel.
Phase II - 11/2017
RV-10 Build Log
Old 03-06-2019, 11:56 AM
rleffler's Avatar
rleffler rleffler is offline
This going to be something that isn't uniform across the fleet, but most people should check the nose wheel tension multiple times a year the first few years.
I severely damage my nose wheel pant when the tension had dropped to 13lbs and landed in a cross wind condition. It was the week before my condition inspection for my third year of flying. I had tightened in twice before that and was planning to check again during my condition inspection. The good news is that three years later and it had held it's tension that entire time.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-06-2019, 12:14 PM
Wow. Thanks for the tip. I'm going to check my breakout force again as soon as possible.
Phase II - 11/2017
RV-10 Build Log
Old 03-06-2019, 07:45 PM
bob888 bob888 is offline
How do you keep your belly so clean?
Old 03-07-2019, 06:54 AM
Raymo's Avatar
Raymo Raymo is offline
I too had the shimmy and breakout force was correct. Upon lifting the nose (holding tail down with tie-down), I found the entire leg was moving side to side. Ordered and installed a close tolerance bolt from ACS and the problem is solved. The old bolt showed signs of wear. The new one fit perfectly. Currently have 225 hrs on the plane with the Anti-Splat nose wheel bearing mod done since day one.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
