Old 09-24-2013, 12:52 PM
Auburntsts's Avatar
Originally Posted by Mike S View Post
A second hole in the shaft that is a half flat of the nut off-----30* will allow either of the holes to be used each time you tighten the nut.
Good solution as I see it.
Sounds reasonable to me.
Todd “I drink and know things” Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-25-2013, 06:58 AM
that is REALLY fascinating how the wheel is cockeyed inthe prop wash. I just assumed it'd straighten right out in the airstream. Great video. Thanks for posting that.
Bob Collins
St. Paul, MN.
RV-12iS finishing kit (still). About 600 hours in. Working on wheelpants.
Builder log
Old 09-25-2013, 08:09 AM
jimbower jimbower is offline
Upon landing a few weeks ago, I had some nosewheel shimmy to the point that my wheel pant was fractured. I checked the breakout force and it was pretty low. Don't know why it wasn't a factor until then, but it took several notches worth of turning to get it right.
I guess it's for the better, because it forced me to do some cleanup on the wheel pant after I fixed it and now I will have to primer and paint it! (I'm having too much fun flying to want the airplane out of service.)
Jim Bower
RV-6A N143DJ
Old 09-25-2013, 08:42 AM
flyboy1963's Avatar
Default alternatives to cup washers alone?
It seems that even at specified crush, the cup washers aren't damping oscillation all that well.
You can easily see with moving it by hand...... Once the breakout force is reached, there is little to no further resistance.
Does anyone have experience with other types of swivel dampers? Not that the tiny oleo style on the nosewheel of a cessna are much better.
....could using a viscous fibre washer of some kind produce a more predictable drag, without affecting steering?
I will speculate that the metal-on-metal washers are going to vary a lot with temperature, oil film, etc.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 09-25-2013, 12:27 PM
walkman's Avatar
walkman walkman is offline
Surely it IS straightened out in the airstream. It's just that the flow coming off the prop corkscrews, it's not parallel to the longitudinal axis of the air raft.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 09-25-2013, 12:44 PM
bkthomps bkthomps is offline
so did you see a speed increase with the straighter pointing nose wheel?
Old 09-25-2013, 02:53 PM
txaviator's Avatar
txaviator txaviator is offline
Looks like that could really have put some wear on the front tire, too!
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 09-25-2013, 03:05 PM
GeneL's Avatar
GeneL GeneL is offline
Default Weathervane
Nose wheel weathervane is NOT due to propwash. It is due to the wheel pant not centered over the nose wheel. To get the amount of turn in the earlier part of video you only need to be off .100 of an inch. Ask me haw I know! Gene
Old 09-25-2013, 09:41 PM
The Wizzard The Wizzard is offline
Default Taildragger
Have you considered turning it into a trail dragger?
Dave Cicciari
3 Paper Airplanes and counting, Honorary "President of The United States of Love"
Dues Paid
Old 09-26-2013, 04:22 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
As has been stated and discussed in many previous texts: do NOT lubricate the Bellville washers (per Van). The nose gear is a taxi gear not a landing gear. Hold that nose wheel off of the pavement till it won't stay up anymore and you will alleviate a lot of problems.
