Old 10-19-2017, 01:00 PM
Default Rattle Can Handle
I'd had issues with using rattle can paints. Typically, my finger would pick up a bit of paint and it would drip down on to the work. Plus, the effort made my finger tired.
I tried this product, which I got for a few bucks at the local hardware store:
What a difference! It holds the can firmly and it's easy to use. This is the right tool.
Strongly recommended if you use rattle can paints.
Also, I got a pack of replacement spray nozzles for these paints. The ones that give a fan-shaped spray give better coverage and use less paint than the factory nozzle, at least for Tempo's Zinc Phosphate primer.
Together with the handle, these made a big improvement.
Old 10-19-2017, 04:09 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've used this for years - definitely worth the small price!
It's almost like using a spray gun - but without the clean-up.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-19-2017, 04:34 PM
rv9builder rv9builder is offline
I found something similar at Aircraft Spruce. It also works great!
http://www.aircraftspruce.com/catalo...ges/cangun.php
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
