Old 10-29-2017, 03:00 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is online now
Default spinning in the Sun... with smoke
https://youtu.be/ojEPgHWhBv4
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with more than 1,700 on the hobbs
Race 771
margarita!
Old 10-29-2017, 05:46 PM
wfinnell wfinnell is offline
Default Cool
Cool! Two thumbs up.
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 10-29-2017, 11:28 PM
eddieseve eddieseve is offline
wow that was amazing, what height where you at when you started and at what height did you finish.
I notice that you have recovered within 3 seconds of applying opposite rudder
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
680 hrs July 2017
Old 10-29-2017, 11:29 PM
Wow that was amazing, what height where you at when you started and at what height did you finish.
Cheers
Eddie Seve
Sydney Australia
680 hrs July 2017
Old 10-30-2017, 07:02 AM
BillL BillL is offline
Default And your conclusion?
Outstanding, the airflow over the emp is interesting!
So - I see you have a new rudder - the old 7, or 8, or latest 6 with .020 skin. Assuming you installed it for speed confidence, and this video is a field test of spin recovery, what is your conclusion of the comparison back to the tall/9 rudder recovery!!?!?!
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 10-30-2017, 08:21 PM
Default 1500 ft for from entry to level exit
Cheers
5,000 ft entry... level exit at 3,500
Stephen
Race 771
margarita!
Old 10-30-2017, 08:39 PM
Default I like the -8 rudder...
My original -7 rudder had accumulated too many cracks at the stiffener ends to go another year with it at Reno... it had been on my list to test out a -8 rudder for potential speed advantage and better flutter resistance and I am glad that I did it.
The -8 has a thicker skin (.20 vs .16) and folded trailing edge.
Every aircraft and loading conditions when testing are different, and my spin testing comparison between the two rudders was not meticulous... for me, the two rudders are very similar in spins.
In general cruise flight, the larger 7/9 rudder resists movement and tends to hold track better. The -8 rudder will move with very light foot pressure.
Flying at maneuvering speeds the 7/9 rudder feels like it is pushing the airplane around with heavy pressure while the -8 rudder is much more fluid and coordinated. This is quite nice.
The 7/9 rudder is much nicer tracking on the ground with the tail in the air at less than flying speeds... there is significant resistance to movement and I could drive around with the tail in the air without much attention. With the -8 rudder you have to be far more attentive.
For me, the -8 rudder is a keeper.
Stephen
Race 771
margarita!
Old 10-30-2017, 09:13 PM
Thanks for an excellent summary, it takes out much of the uncertainty of a rudder change. My tall-7 will be on for first flight, but the -8 is standing by. Excellent to hear that your plane had little difference, I could have imagined the heavier engine up front might have revealed any difference.
Pausing that video right at the end where the stall, spin, and recovery track are visible is outstanding!
Bill
1st Flight 1-27-18
2017 Dues Paid
Old 10-30-2017, 09:23 PM
Default the smoke really held together nicely
The day was perfect for hanging smoke
Stephen
Race 771
margarita!
Old 10-31-2017, 09:09 AM
tfriendshuh tfriendshuh is offline
very nice - thanks for sharing
tim
RV-8A N6677F IO360 CS
Dues paid through 2018
