Old 11-10-2018, 05:00 PM
dvalle dvalle is offline
Default ADS-B Navworx Units
I have several more units, they require a 430W/530W or approved WAAS source. Please don't say they are not legal as they are with approved WAAS source (per AMOC). They also qualify for the FAA rebate making them a REAL good deal at $500 after rebate. I can assist with all paperwork.
Old 11-10-2018, 07:55 PM
DBKrueger DBKrueger is offline
What is the model of these units? Instructions ?
Old 11-10-2018, 10:07 PM
Sorry, those that are affected by the AD, 0012 and 0013 . Hence the reason you must have WAAS source. As I said, I will assist with all paperwork, that includes install instructions.
Old 11-11-2018, 07:28 AM
maniago's Avatar
maniago maniago is offline
So your selling price is $500?
Mani
MustangII (FoldingWing) "FirewallFwd&sundries": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 11-11-2018, 08:04 AM
FasGlas's Avatar
FasGlas FasGlas is offline
I believe he is selling them for $1000 and with an FAA $500 rebate the final cost to you would be $500. Might as well buy a Sky Beacon that doesn't have the AD.
Old 11-11-2018, 08:41 AM
REAL good deal at $500 after rebate....
Not sure but thought the Skybeacon is more than double that after rebate ($1300). However, the Skybeacon is supposedly easier to install as the Navworx requires 2 wires from the 430W/530W. If you don't have the WAAS source approved GPS (per AMOC), you cannot use the Navworx.
Old 11-11-2018, 08:46 AM
maniago's Avatar
...uh, yeah hate to burst your bubble, but going rate is $150-200 (internal box options depending) regardless of rebate.........
Mani
N251Y (res)
Dec2017
Old 11-11-2018, 10:22 AM
wookiemail wookiemail is offline
What is the long part number for these? 0012 or 0013 will be part of it. BH
Old 11-11-2018, 10:45 AM
Turbo69bird Turbo69bird is offline
So these are the units with a sil of 0000?
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
Old 11-11-2018, 07:36 PM
Geee, yes, these ARE the units in the AD. BUT, you can use them with a 430W/530W per the AMOC.
Just thought I'd offer on Van's because, as RV6 owner, I personally always tried to be economical. Unfortunately, I did not have a WAAS GPS so I had to sell mine a while back. I am installing one in a another RV6 right now (that has a 530W).
Please read this to save a long list of questions/opinions. At the bottom there is a link to the final rule which shows the part numbers. We all know, the FAA does their homework before approving an AMOC:-).
https://www.aopa.org/go-fly/aircraft...oc-information
