I?m completing a 9A. Instrument panel has all AFS products: 5600 EFIS, Auto Pilot, Comm. Radio, Intercom, and stand-alone AOA. Panel also has a Dynon D-6 back-up screen. Pitot tested great-all working as expected. My static system is another issue. I use a glue syringe to test in very small puffs of air. Hooking up the static line at the panel, the D-6 and auto pilot work fine. Hooking up the static line at the ADHARS and the 5600 works fine. Hook up the test at the rear ?T? connection, which joins the two static ports, the ADHARS, and the static line running to the panel, and I get nothing. Covering one port and blowing air in the other port and I get nothing. Have disconnected the static line running to the panel at the ?T? connection and blown air backwards to the static ports. Air comes out both ports, meaning no clog in the line. AFS tells me everything should work, but it doesn?t. What am I doing wrong? Anyone had a similar experience, with a happy outcome they could share?
