Torque for PMag install ...
swisseagle
Hello,
heading to the airport to make service/annual work.
Need to pull the PMags to check the cotter pin.
Somehow unsure about the torque on the studs to fix the PMag ...
Do I apply just standard Lycoming torque on the nut/stud for the correct size?
Acc. to Table 1?
Thanks for any heads up-
Thank you Mike!
The star-washer can de a show-stopper ... if you run out of them.
There was not enough time to do it today, but tomorrow.
204" pounds?
Wondering if there is a reference for this? Lycoming manual indicates 1/4" bolt and nuts should be 96-106 "pounds. I think they are 1/4". I want to do it right so they dont fall out.
U are correct - 5/16 and 204"/pounds. Thanx. I'm going to verify the torque on mine tomorrow morning.
