ERushing
Good Afternoon,
I need some quick dimensions because the Quick-builders did not drill the holes at the aft end of the F1046 Longerons.
Page 29-2, Step 4 - Holes on the F1046 longerons were supposed to be match drilled to the template. They weren't. Could anyone take a look at their longerons and tell me the spacing between the bolt holes and the exact distance from the end of the longeron to the aft-most bolt hole? and the distance from the aft rivet in the left longeron.
Unfortunately Vans is closed today.
I think I can simply drill these holes from the top as long as I'm centered to the bottom side and drilling at 90 deg.
Any guidance would be appreciated.
I was planning to get the tailcone attached this weekend and this would put an abrupt end to those plans!
Thanks for any help!!
