Old 02-01-2018, 11:53 AM
Bernard Hartnell Bernard Hartnell is offline
Question 14A quick oil drain plug
While I see Vans sells an oil quick drain, has any 14A bought one. I donít know if it will fit with the exhaust cross over just below the plug grain hole.
Old 02-01-2018, 12:37 PM
n982sx n982sx is offline
I didn't buy it from Van's but I have the same one shown in their catalog and there is no clearance issue.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-01-2018, 01:27 PM
Both the RV-14 and 14A prototypes have oil quick drain valves installed.
They are used for convenience only and not to do oil changes without removing the cowl (full engine compartment inspections are done at every oil change).
Scott McDaniels
Hubbard, Oregon
Old 02-01-2018, 10:06 PM
Understand Scott, Iíve never done an oil change with the cowl on. I also always change the filter. I see the filter as cheep medicine given the overall cost of the motor. Even Walmart does this with their cheapest oil changes. So if thatís the standard for cars all the more reason to do it with my plane. Back to the quick drain; thanks for your thoughts ind info on the 14 tail dragger because I have the IO360 also but with the forward prop govenor. But our sumps May be different because the crossover exhaust is directly below the drain plug. Looks like about 3Ē below the drain hole. Should that distance be no factor for the Vans catolog quick drain?
Old 02-02-2018, 09:33 AM
Originally Posted by Bernard Hartnell View Post
Understand Scott, I’ve never done an oil change with the cowl on. I also always change the filter. I see the filter as cheep medicine given the overall cost of the motor. Even Walmart does this with their cheapest oil changes. So if that’s the standard for cars all the more reason to do it with my plane. Back to the quick drain; thanks for your thoughts ind info on the 14 tail dragger because I have the IO360 also but with the forward prop govenor. But our sumps May be different because the crossover exhaust is directly below the drain plug. Looks like about 3” below the drain hole. Should that distance be no factor for the Vans catolog quick drain?
The standard models of angle valve engines recommended for the RV-14 have an oil drain port on the side edge of the sump in the back.
This can be seen on DWG 43-05. It is the unlabeled fitting port adjacent to the fuel pump inlet fitting in the drawing. This is where the oil drain is installed on both RV-14 prototypes.
My comment related to short cut oil changes is because many RV owners with quick drains do this. It is possible to drain the oil using a hose attached to the quick drain, and also change the filter, with only the top half of the cowl removed.
It is a very bad practice and I encourage all RV owners to not be tempted.
Complete cowl removal for the oil change is a perfect time to give the entire engine installation a good careful look over.
If everyone did this, I believe that "guess what happened to me today" storys caused by failures in the engine compartment would be just about nonexistent.
BTW, using the drain port I described is beneficial in more fully draining the oil because of the nose up attitude. Particularly on the tail dragger.
Scott McDaniels
Hubbard, Oregon
Old 02-02-2018, 03:59 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
One of the best decisions we made was the installation of camlocks on both the upper and lower cowls. Complete removal in less than 10 minutes. With a quick drain and flex funnel the oil is drained warm in another 10. We install our alternate set of spark plugs at every oil change.(50 hrs) Total job in an hour.
Old 02-04-2018, 07:26 AM
Erimo's Avatar
Erimo Erimo is offline
Hi Scott,
My engine is know unpacked and I started to prepare it (section 43). The ports are equipped but I didn't see any information about oil drain valve and where to install it, just about sniffle valve with small port. When I read Lycomming manual, the horizontal sump is not the same of mine and the manual version is 01/01/2017 !!!.
I missed something ?
Eric
RV 14A - #140252 - Flying
France
Dues paid for 2020
Old 02-02-2018, 07:43 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Curious how that could be done?
I must be missing something > Even if someone wanted to change the oil without removing the cowling, how could that be done? Maybe some kind of in-place tubing line or a hole drilled in the bottom cowling under the quick drain.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
1946 Bellanca Cruisair 14-13-2 (73 YRS OLD 8/15/19)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/19 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 02-02-2018, 09:29 AM
Bavafa Bavafa is offline
Suck it up like some of the car dealership do but that is a very poor job of maintaining your engine. One other task for oil change is to have good look around your engine compartment and make sure there is no abnormal wear or other issues exist.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
