Old 01-09-2019, 06:28 PM
BillL BillL is offline
Some good details to the basic "drill better". I think end of the day produced my most mistakes. That said, I found the longer rivets are much harder to remove. I do use the progressive drill method, but I do have a full drill index on hand to step up in small sizes. I also made an anvil inspired by wirejock's post to use to back up the rivet to help drive it out. Also you can grind down the diameter (to #40 size) of a Harbor Freight automatic center punch and use it to drive out the rivets, the hammer and punch is for the most stubborn ones (like yours).
http://www.vansairforce.com/communit...99&postcount=2
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-10-2019, 04:05 PM
GeoffP GeoffP is offline
Default I Agree
Originally Posted by David Paule View Post
To remove a rivet, I like to use a smaller drill to go about 2/3 of the way through. For this, I use a drill bit ten numbers smaller than is appropriate for the rivet. So for a -4 rivet, I'd first use a #40 drill.
Then I drill just the head off with teh correct drill. For this example, I'd drill just the head with #30. Then pop the head off and use a punch that's 3/32" diameter, matching the #40 hole, to knock the body out. The smaller drill weakens the body and makes it easier to punch out.
I've basically done the same thing to remove long (-8, -9) rivets in the exact same locations as the OP in my RV9 HS, and it works a treat. I often found when I put the #30 drill in after drilling through with the #40 that the head snaps off when the drill bit "grabs" it. I even have one I drilled a long way through with a #40 so there's just a thin-walled tube about 10mm long attached to the shop head! As others have mentioned, go slow, pay attention, and make sure the drill is dead in line with the rivet.
RV-9, Emp mostly done, Wings about to start.
