Old 01-08-2019, 06:18 PM
RussellT RussellT is offline
I am interested in this one as well having just wired my starter switch, exactly the same set up as Jeff in the above post except I used the strobe circuit to enable the start button.
RV 3B. Very slow build. At fwf & wiring..
Old 01-08-2019, 06:21 PM
jeffwhip jeffwhip is offline
Originally Posted by DaveO View Post
Using the Vertical Power system you have to power it up before the starter button will engage. At least that was the way I wired the system. So there is no accidental starting the motor.
Dave,
Can you give me any guidance on how to set that up?
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - Complete
Cabin Cover - Complete (wheewww!)
FWF - Complete
EFII 32 - In Progress
Dues Paid Through 2018
Old 01-08-2019, 06:25 PM
Originally Posted by AAflyer View Post
I wired a guarded cut-out switch inside my forward baggage compartment...which is lockable. Lets me leave the canopy open without fear of someone pushing a hot starter button.
I thought about doing something like this, but should the switch in the baggage compartment fail inflight and you subsequently had an engine failure, the engine would not start. Hence, I'm trying to find a way to balance safety yet keep the start sequence simple. I'm not throwing stones at anyone who has done this, simply trying to figure this out!
Rudder - Complete
FWF - Complete
Old 01-08-2019, 06:33 PM
Walt's Avatar
Walt Walt is offline
I do push button start switches on 90% of my panel installs, on a few occasions customers wanted a way to kill the start circuit so I will mount the start CB on the lower bent edge of the panel or somewhere out of the way but easily reachable, so the breaker can be pulled to disable the system if desired.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-08-2019, 06:36 PM
Just use a key-switch to control the master contactor.
The 1st example that popped up:
https://www.amazon.com/Switch-Remova...50526633&psc=1
Old 01-08-2019, 07:41 PM
Thanks for all the advice.
Rudder - Complete
FWF - Complete
Old 01-08-2019, 07:47 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just realize that in most cases, when teh engine quits, the poropellor keeps windmilling - you have to fly very, very slowly (and intentionally) to get it to stop. Bottom line - you donít need a starter to restart in the air. Just restore fuel and/or spark.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-08-2019, 09:42 PM
Mel's Avatar
Mel Mel is offline
Just to add to what Ironflight says, If the failure is such that the prop isn't windmilling, you probably shouldn't use the starter anyway.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-08-2019, 09:46 PM
mfleming's Avatar
mfleming mfleming is offline
I too am thinking of a push button start switch.
My concerns are not accidentally hitting the starter or a stolen airplane. No, My concern is leaving the mags hot while I'm outside the airplane.
For over 40 years, when I'm not in the airplane (ie preflight), if I'm going to touch the propeller, I look up to see if the keys are on the glare shield. If not, I check the mag switch and/or check my pockets for the keys. I haven't got beyond how to remedy that with a keyless system except maybe with dual P-mags that's not an issue.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 01-09-2019, 01:08 AM
Yen Yen is offline
I use a push button starter and two switches for the two mags. The right mag has a double pole double throw switch, If the switch is off, then the P lead is not grounded and the starter solenoid is not powered. If the switch is on, then the P lead is grounded and the starter solenoid is live, just waiting for the button to be pushed. Works well and starting I turn R mag off, press the button and when it fires turn the right mag on, which kills power to the start button.
