Old 01-05-2019, 02:29 PM
lr172 lr172 is offline
Default Question on Door Finishing for MC Seals
I need to build up the area around the door pin guides to be flush with the door's inner surface. I was thinking of epoxy or strong filler, however, I am concerned that nothing will stick to UHMW material. I am wondering if the epoxy only bonds at the edges where the F/G is at, it may not be strong enough to hold on over the long haul.
I was considering forming a piece of F/G of the right thickness and bonding it at the edges with the door F/G. Wondering what creative methods others have used for this issue.
Thanks for any assistance.
EDIT: Just found Ivan's method of using balsa plywood and it looks like a good idea.
N64LR
RV-10 in progress
Old 01-05-2019, 06:23 PM
Electrogunner Electrogunner is offline
Default Filler
I just used some of the leftover door scraps from the trimming of the door windows. Instead of balsa wood, which I don't have on hand.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 01-05-2019, 10:13 PM
majuro15's Avatar
majuro15 majuro15 is offline
I just did epoxy with flox right on the scuffed UHMW blocks. I did use balsa wood for hinge covers.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Powered on!
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
