Old 01-04-2019, 07:32 PM
MJarreau MJarreau is offline
Default HS Inboard Hinge Bracket Assembly
Plans page 8-3, Step 2 has you bolt the assembly to the HS rear spar. No biggie, there. It calls out hardware to use. Section 5.20 says to be certain to put a washer on the head of the bolt. The plans do not call out a washer.
Should we add the washer at the head per section 5.20?
Happy New Year!
TIA,
Mike
DUES REMINDER: DEC 2019
Remember the most exciting and satisfying part is the empennage. It gives you the feel you almost accomplished the airframe. Then in three years you hang the engine... and you suddenly understand you haven't started yet.
-Vlad Karpayev (http://www.vansairforce.com/communit...=1#post1344505)
Old 01-04-2019, 08:09 PM
Brantel's Avatar
Brantel Brantel is offline
Happy New Year!
TIA,
Mike
Mike,
Not in this case. In this case you hold the bolt and torque the nut so the nut has a washer.
5.20 is referring to a case where you must torque the bolt head. In that case you need a washer under the bolt head. Think bolt going into a blind threaded hole or a nutplate.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
