Old 01-04-2019, 04:02 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Tunnel access panel location
Hey - looking at many of the "what would you have done different" posts, it seems like adding an access panel to one or both sides of the tunnel is at the top of the list. So I figured it would make sense to add these before I riveted on the side skins.
What I'd like to know from the folks that are maintaining a RV-10, is exactly where along the tunnel is the best place to locate the openings... better further forward, aft, or pretty much centered?
If anyone has pictures of what has worked well for them, I'd love to see them.
Jason
Jason Tremble RV-7A (Flying)
IO-375, Hartzell Prop
Garmin G3X Touch, VP-X Pro
Old 01-04-2019, 04:12 PM
raabs raabs is offline
https://www.airward.com/products/rv-...ersunk-screws#
http://buildingrv10.blogspot.com/201...ess-panel.html
Rob Kelly
FL
Old 01-08-2019, 07:29 PM
jeffwhip jeffwhip is offline
Jason
Jason,
It all depends on where you plan on mounting things in the tunnel. For instance, I'm using the EFII 32 system and will be placing my electrical fuel pumps in the tunnel. In my case, I put one one access panel in beforehand but after placing my EFII 32 pieces in there, I wish my access panel was further aft.
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - In the Works!
Cabin Cover - Complete (wheewww!)
Dues Paid Through 2018
Old 01-09-2019, 02:29 PM
Lynnb's Avatar
Lynnb Lynnb is offline
Look at where you're fuel filter will be, you want access so you can easily get to this each year at your annual.
Lynn
RV-10 in Process
