Old 01-03-2019, 11:50 PM
bkmerrill bkmerrill is offline
Angry How bad is it? (back riveting oops)
Well, I did it. The thing I said I wouldn't do. I riveted off the edge of my back rivet plate and damaged my rudder skin. SEE PHOTOS HERE.
Will be putting a call into Vans, but hoping someone here can talk me off the cliff. Is this a, "Buy a new skin don't even think about continuing," OR "A little paint filler after completion will take care of that?"
Few positives: 1) It was barely off the plate, so wasn't able to push down to workbench and punch through, 2) I caught it on about the 3rd hit of the rivet gun. I went ahead and dimpled the hole again, and that looks fine along with the stiffener, but wondering about the dent/crease on the outside of the skin. Thoughts?
Brandon Merrill
Houston, TX
RV-10 — Empennage In Progress
https://merrillfamrv10.wordpress.com/
*2018 Dues Paid*
Old 01-04-2019, 01:27 AM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Doesn’t look too bad to me, as long as the crease isn’t too sharp/deep? If the dimpled hole is compromised, you could just add an extra rivet either side and fill before paint, the same as you would treat the inevitable double dimple or smiley. My opinion only
Paid up - Dec 2018
Old 01-04-2019, 01:28 AM
Aero_Octaveus Aero_Octaveus is offline
I don't think that looks bad at all. Honestly do not beat yourself up. Many, many builders have done the same thing and quite frankly in my opinion every RV needs to have one of these somewhere for it to be a real plane . I suspect they will get you to buff out the sharp edges and build on. A little filler and paint makes it disappear.
Call Vans and tell them the web address to see your photos. They always give the best advice.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2018 Donation Current
http://garetsrv.blogspot.ca/
Old 01-04-2019, 06:14 AM
maniago's Avatar
maniago maniago is offline
You have nothing to worry about structurally. Do a very slight bit of buffing at the edges and move on; this is nothing to be concerned about. Your ego may be bruised, but your plane isnt.
Build on MacDuff!
Mani
MustangII (FoldingWing) "FirewallFwd&sundries": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 01-04-2019, 06:27 AM
Bruce's Avatar
Bruce Bruce is offline
Brandon,
You can also flip your dies in the dimple machine and you can get rid of the drag marks from hole to hole.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2018 DUES PAID
Old 01-04-2019, 07:20 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Default Welcome to the club!
As others have said, eventually all of us make an "oops" like this. Sometimes more spectacular, sometimes less.
It's all part of the building / learning process. Doesn't looks like it's too bad and hopefully you can clean it up and build on. (If you are stressing over it, just order new parts) Just about anything can be fixed one way or another.
(I was worried you had a crack in photo 4, but looks like that was just the lighting for that one photo).
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - in progress
RV10builder.com
PPL / IR - KVKX / KHEF
Old 01-04-2019, 07:39 AM
BillL BillL is offline
+1 I did the same, and have suggested to others to use a magnet to mark the end of the backplate, or make a huge plate so ends are never met.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 01-04-2019, 08:49 AM
airtractor8 airtractor8 is offline
Are you guys for real sugar coating this?
Pic 5 clearly shows a crack in the skin at the 270 degree position from the hole unless I'm mistaken?
If you look hard enough it is also visible in pic 1 & 10.
That definitely is a structural problem and will become a bigger one in time if not addressed now.
At the very least it needs to be stop drilled before moving on. ( or the skin replacing if you are building a "show plane")
Filler and paint can hide many mistakes but it does nothing for the structural integrity of the airframe.
Old 01-04-2019, 09:11 AM
BrianDC's Avatar
I was thinking there was a crack as well, but can't 100% be sure it wasn't from the light. It looked bad on one picture, but could have just been a reflection. OP will need to verify the dimple isn't cracked.
Brian Lester
RV10 - #41778
Wings - in progress
RV10builder.com
Old 01-04-2019, 09:19 AM
There is not a crack at the hole. What y’all are seeing is tape residue from the rivet tape I was using getting torn/smeared during the oops. I cleaned it off for some of the photos. The only visible damage is the dent/crease on the outside of the skin.
I cannot see the inside of the skin because the stiffener is already in place. I’m considering drilling out the stiffener enough that I can inspect the inside surface of the skin.
Brandon Merrill
Houston, TX
*2018 Dues Paid*
