Old 12-26-2018, 04:58 PM
KatanaPilot KatanaPilot is offline
Default Puddle lighting
Has anyone come up with a creative installation of "puddle" lamps - possibly in the doors of an RV-10?
I was looking at one of the RV-10's in the hangar today and thought that lighting mounted in the doors that could illuminate the wing walk area might be a nice modification.
Coming up with a reasonable routing method from the cabin cover into the hinged door seems to be the biggest challenge.
Has anyone done this or mounted exterior lighting in another location that would illuminate the wing walk area?
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction
Old 12-27-2018, 08:17 AM
mike newall's Avatar
Has to have the logo as well
Like a 'Stang or a Range Rover
Donated in 2018
Old 12-27-2018, 09:09 AM
ppilotmike's Avatar
ppilotmike ppilotmike is online now
Krea,
Yes, this modification has been done by other RV-10 builders. Ed Krantz and Justin Twilbeck are two builders that immediately come to mind. Aveo Engineering also sells lights that mount on the side of the fuselage for lighting the leading edge of the wing for ice detection, but I belive their system could also be employed to light the wing walk without having to put wires through the gull wing doors. Happy building.
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 Working on the "Dreaded Doors"
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 12-27-2018, 12:50 PM
Yes, maybe Geoff at Aerosport will add the logo and lights to the carbon fiber door sills he makes
Originally Posted by ppilotmike View Post
Krea,
Glad to hear that. I didn't think this was a unique idea, but it was one I would like to include.
Krea Ellis
Locust Grove, GA
RV-7A Phase 2
Old 12-27-2018, 01:40 PM
fabricflyer fabricflyer is offline
Default lighting in door
Krea,
Don't know if you can route wires to hinges on doors, but if you can, you can use an old trick we used on stereos in the seventies. We used the two hinges on the fold out speakers to transfer the signal instead of having exposed wires.
Maybe you can route a channel in the fiberglass and then cover it.
Allen
7A very slow build
Old 12-28-2018, 11:15 AM
majuro15's Avatar
majuro15 majuro15 is offline
Sean at Plane Around has some very nice LED's that I'm using (and others have) in the doors to light the wing walks. I thought about doing some tiedown lights or somehow have an exterior light that comes on to light up the step but the complexity of weather sealing it overrode the requirement. I think the door light will suffice for pax and the Mrs.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Powered on!
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
Old 12-28-2018, 11:33 AM
N941WR's Avatar
N941WR N941WR is offline
A friend put white single LED spot lights under his wings, next to the tiedown rings, wired into his position lights.
The master had to be on for the position lights to work. His thought was that if the ground is lit around his plane, then the was unlikely to leave his master on.
I would think there is a remote available, similar to a car remote, that could turn on the flood lights upon command, and would automatically turn them off after X minutes.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-29-2018, 08:10 PM
Drippy Drippy is offline
Default Slow tech solution
Guys,
I have added three lights to my RV all battery operated. I bought a 4 pack of adhesive backed floods and mounted one above the baggage area and one above the back seat, two spares for later:-). I also have a nice overhead red cockpit panel flood light from spruce again battery operated.
I also keep two little red flashlight I bought on-line, one in the back of each seat, for easy access. I also keep a set of spare batteries for everything.
I don't like to fly at night, so only go enough to remain current and the occasional must trip to visit the kids. But after returning one night from my college sons baseball game and the auto dimmer on my avydine Sh** the bed I created a little night flight check list. A reminder to check batteries, lights and a quick reference on how to dim everything.
Anyway just rambling . . . but the flood in the back, really just behind the front seats does a good job of lighting the top of the wing for exit, hate to use it on entry though since it will kill your night vision.
Mike
N95VT
RV10
~150hrs flying
