Old 11-10-2018, 12:23 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Originally Posted by MConner View Post
And a a 50 year old airframe with retracts and an FAA strait jacket on changes to avionics and airframes? Not even apples and oranges.
Being the manufacturer and maintenance shop, able to do modifications and use your own fabricated parts or "experimental" parts (engine, prop, avionics, EFIS), with less FAA restrictions, is priceless (and less expensive to own because of that). Resale of RV's had proved to be excellent.
For 2 seats side-by -side or tandem there are not many GA aircraft to compare to the RV-7/14 or RV-4/8, so that helps decision to built. Most builders love working with their hands, process and learning.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
Old 11-10-2018, 12:51 PM
jliltd jliltd is offline
I own a 260B Comanche and it is fantastic, stable, speedy, safe and has a huge CG range. No cowl flaps or cooling problems. And maintenance isn't too bad if kept up with.
Jim
RV-8
RV-3B
Old 11-10-2018, 01:14 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Because we're passionate......
Originally Posted by Kyle Boatright View Post
A lot of very rational people would choose the Comanche or an equivalent Bo over the RV-10, given the $100k cost difference. We buy/build RV's (and own Comanches) because we're passionate, not because any of it makes sense or can be reasonably justified.
Kyle,
You hit the nail right on the head with the above statement.
"We buy/build RV's (and own Comanches) because we're passionate, not because any of it makes sense or can be reasonably justified."
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1150hrs.
Dual GRT 8.4" EFIS, TT A/P, Avidyne IFD440, Dual EI's
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 12-30-2018, 05:29 PM
grubbat's Avatar
grubbat grubbat is offline
Default Indicated vs True
Descending out of 17,000ft at VNE (not recommended), the RV-10 would need to keep indicated airspeed around 148kts or less due to the weaker structure. It is true air speed limited to 200kts.
On the other hand, the stronger yet older (50yr) Comanche could descend at 201kts INDICATED which trues out to around 270kts.
Once the -10 gets down to around 8500ft, it'll will be back in the hunt..... unless the Comanche has already landed, refueled, and robbed the courtesy car. (I hate it when that happens!)
Happy New Year!
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
