$30 for a normal crimp-on TNC male connector? Ouch!
I guess the 225555-6 is overkill, but it's what Stein provided with my 430W, and in my experience, they usually have a reason for doing things one way vs. another.
...the install manual for the GNS430W says a minimum length of 13 feet RG400 is needed to get proper impedance. Any additional connections would add some more impedance. ...
I'm curious what the reason is. If you get a chance to ask them (or maybe Stein will jump in here on this thread) I'd be interested to hear the answer.
What connector does he provide for the radio end of the cable? If it's one of those commercial-grade Amphenol male BNC's that they sell, that's a curious combination, exotic mil-spec TNC with rather low-end BNC.
Now, whatever Stein is doing here, I'm sure it works fine. Not criticizing, just wondering what the rationale is.
--Paul
The only extra connectors I have are the ones to convert the TNC to regular BNC so I can use the less expensive BNC connectors. The converters are less than $2. BNC connectors are cheap compared to the TNC ones.
I don't suggest adding a bunch of extra connectors in the line just to get the minimum dB of loss. Just add the extra coax.
I've have tested some of these "less expensive" connectors with my transponder test set and the real cheapies (from Fry's) had a huge signal loss (like 3 db).
These are much better Mouser Part #: 523-242149
