O-320 E2D Cylinder 3 temp lowers at WOT
jeffsvan
Team,
I searched the Forums and did not see any posts referencing my issue:
Just noticed a possible abnormality.
While running 70% or less, I have even CHT and EGT across all 4 cylinders.
roughly 1400 EGT, and 310 CHT
But when I go full throttle or above 75% I am seeing cylinder #3 getting cooler temperatures of about 1280 degF, and the other cylinders go up to 1500. When I pull back to 70% they all even back out at 1400.
My plan is to switch the probes on my engine monitor and see if the problem remains or follows the probes. Maybe I have a probe going south.
Any ideas? Is there a possible issue I am not considering?
thanks
