Old 09-16-2017, 06:52 AM
TShort TShort is online now
Default B&C Starter
I'm planning to replace the starter during the panel rebuild this winter - currently have the Skytec -LS, and was planning to swap to the -NL.
Does anyone have experience with the B&C starter? Is it a drop in replacement? How is it performancewise? Any weight benefit? (I can't seem to find weight specs on their web site)
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Old 09-16-2017, 07:29 AM
Chkaharyer99 Chkaharyer99 is offline
I replaced the broken Skytec Lightweight starter on my RV-8 with the B&C starter.
In my case it wasn't a drop in replacement. I had to modify my snorkel and buy a different mixture lever with a greater offset in order to clear the starter. With my Bendix FI it was a tight fit.
Performance comparison? In my experiemce the B&C spins the prop on the first attempt and spins it faster. Starts great. The SkyTec required 2-3 bumps before it would turn.
No weight benefit in my case. I think I gained a pound. For me it was worth it.
Call B&C. I think you'll be impressed with their customer service. I am.
Charlie
RV-8
Old 09-16-2017, 07:42 AM
Default +1
Although I am not flying yet, the customer service at B&C is second to none...highly recommended.
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 09-16-2017, 02:17 PM
Thanks for the replies.
I've no doubt B&C is a great company ... have read lots of positive reviews.
I know the -NL starter is used by lots of the -10 owners, but haven't heard reviews of the B&C unit.
If it requires redo of baffles, etc or other stuff, it's a no go for me (too many other projects, and the panel will be work enough) ... but if it is a drop in fit and is a better unit I might consider it.
Thomas Short
Old 09-16-2017, 02:45 PM
bcondrey bcondrey is offline
The B&C starter is a drop in for an RV-10 with no change - I've used them in 2 RV-10s.
Bob
RV-10 #2 99.9% Complete
Old 09-16-2017, 04:54 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Years ago I gave up on my LS starter after nearly leaving me stranded with a approaching tornado. I replace it with a B&C and never looked back. The B&C has never let me down.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993
RV-3B Tail, wings and fuselage.
Old 09-16-2017, 07:27 PM
I asked the same question some number of years ago. On this forum there seemed to be a strong leaning toward Skytec. When I asked on another type club builders forum I received some very informative responses. I think the most convincing was the high-time builder who indicated he installed the B&C on his new engine and new aircraft. The engine was removed at TBO and overhauled with the B&C just bolted back on the engine. At that time he had put something like 400 hours on his overhauled engine and the B&C was still going strong with something in excess of 2800 hours since new, and never touched other than removal and re-installation when the engine was overhauled.
BTW the reason I was asking this same question was because I had sold my brand new Skytec 149LS starter to an RV8 pilot who was stranded at our field on a Sunday morning when his Skytec broke. It was the typical break - a crack in the aluminum nose casting. I've since seen several that have gone this same way.
The B&C cranks our O-360 with authority.
Old 09-16-2017, 09:01 PM
jakej jakej is offline
FWIW - I started with a B7C unit in 1994 & at 2000 replaced engine. Contacted B&C re refurbish & after some pictures & questions they said it was good to continue without any work. It now has 2300 + hrs & still going strong
