I bought a kit from another guy who put the port for the static in from the outside instead of from the inside and it looks to me that he used the good stuff to glue it in. I need to take it out and put it in from the inside. after I do that I will have a bigger hole there then what should of been. My question is has anyone glued one in and had to take it out. If so how did you do it. This is the port on the side farther down the tail from the baggage area. Thanks
