Old 10-06-2019, 03:37 PM
RobertD RobertD is offline
Originally Posted by BobTurner View Post
No. To generate a report you should be in ‘rule’ airspace - airspace where, by rule, adsb-out will be required in Jan. I flew above 10000’, and inside a Mode C veil, but never talked to anyone, and squawked 1200 the whole time. Got a report and a rebate just fine. Turn anonymous mode off.
thanks, I was starting to figure that was the case. I think I'm going to blast off, fly over KGSO's airspace for a while and see what happens.
Robert Dickson
KSCR
RV-6A 0-360 CS
Old 10-12-2019, 11:49 AM
Default PAPR time?
I'm homing in on the proper transponder threshold setting.The only issue I've had is the barometric altitude. I got some good advice from Uavionix to monitor that number with the app while reducing the threshold 50-75 at a time, watching for when it "populated." It did but then would drop out so I kept lowering it until the baro alt number stayed stable.
My issue is how to put the time into the papr report. I want the report to start at 1445 zulu (when the baro alt stabilized) but when I put that time into the form the report gives me the entire flight. I know I'm missing something basic, but what is it?
thx
Robert Dickson
KSCR
RV-6A 0-360 CS
Old 10-12-2019, 04:37 PM
I do not think you can request certain times. You always get data from the entire flight closest to the time (Z) you entered.
Old 10-12-2019, 09:38 PM
donaziza's Avatar
donaziza donaziza is offline
thx
Yeah, that happened to me to. But IT DOES ask for a very specific zulu time on the report. But you WILL get the entire flight time. Government ( Make sure you put a colon between the hour and the minute. ie 19:35, not 1935) (I just picked the time that was midway between my flight.)
