In the Van?s weight and balance paperwork it shows the baggage area max weight at 150 lbs. On the Van?s WEB page site for the -10 specs, it shows 100 lbs max. What max weight for the baggage area do you use.
The factory recommended baggage area weight limits are typically because of structural design.
Confirming that the airplane stays within CG limits is the pilots responsibility.
