25/100 hour engine checklist
yankee-flyer
If I'm reading my maintennance manual correctly, it doesn't call for a compression check until 200 hours. So the 25-hour check will be a visual check plus oil change?? Can the more experienced rotac operators (anyone with more than my 18 hours) please verify this?
THANKS
Wayne 120241
Wayne -
The 25 hr inspection is the same as the 100 hr:
visual inspection, check torque on all external screws/nuts, idle check, carb sync, float bowl inspection, check spark plug gap, friction torque on gearbox, ......the checklist is very comprehensive.
Right
And as best I can read the checklist, a compression check isn't done until 200 hours and then every 200 after that. IF I"m reading it right
Wayne
