AJ85WA
Hi Guys
Need some input from guys with MGL avionics.
I am using the T1A9-1(Sold by MGL) sender mounted to my magneto to pickup RPM reading. This is wired directly to the RDAC X unit.
The instructions I received in the box say not to wire a resistor between the power and signal but then the online instructions say you need one?
Can someone tell me if this would cause me not to get a RPM reading at all?
Thanks AJ
Thanks AJ
