My ADAHRS keeps failing the acceleration (top line) part of the engine run-up test (but passes the other two elements of the test). The unit is mounted on the sub panel behind the instrument panel (not on the firewall) just in front of the pilot. I have added a doubler and even tried the tie down with ratchet straps while testing as suggested by one post on this site. That said, all seems to be working fine and the engine/plane do not seem to have a detectable excessive vibration. I am thinking of just giving up and ignoring this problem. Have others done so and had a problem down the road? Alternative solutions other than moving the ADAHRS (which would require major rewiring and and replumbing the pitot/static/AOA)?
