Why the need for a secondary latch
The Van's demo plane lost a door also or severely damaged it before anyone else had a chance to lose theirs. I had to open my door after the explosion blew the windows out. If the doors can withstand an explosion like that there is no pressure in flight that could be worse.....to the best of my knowledge, two -10's have lost a door each, in flight. One airplane is from Georgia, the other happened in South Africa.
The Georgia airplane lost the right door and it impacted the right stab with enough force (during cruise), that it bent the right stab backwards and kinked the left side of the fuselage. It was disassembled and taken to Florida where a new tailcone was added. I spoke with Jesse Saint, the man who did the work.
Van has since provided a secondary safety latch that mounts near the center of the lower door edge that is supposed to address this issue, but as Vic said, if the two pins are engaged front and rear, they're not coming open,
Best,
Are there any new ideas on the secondary door latch for the RV-10 doors? I was watching this a while back but havent had time to reseach the possible variations. What's been working?
Chad,
I would highly recommend a solution that integrates with the door handle. I don't want to fumble with a second latch handle in an emergency.
Bob
I'm a fan of Sean's design. Works well to solve issue I had in drawing door in to allow closing with seals that were not compressing easily. Had some bowing of lower door at cruise ie 1/8 inch that generated a draft. That is solved. It provides a very solid safety latch. No way this door could open in flight. To those that are concerned with opening the door quickly this is a perfect solution. I installed this on a flying aircraft with no big issues.
Doesn't a Piper Tomahawk have two latches and that system has been working fine for years?
