Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 08-22-2018, 12:16 AM
mbauer mbauer is offline
Default Such A Thing As Lube For the O-Ring on the Fuel Cap?
My fuel caps are getting harder and harder to remove and then put back. When I first purchased my RV-6 it had some kind of "product" that seemed to help, now that stuff is acting like a glue.
Is there a lube of some kind that I can use to stop the O-rings from sticking?
Or best to buy new O-rings and clean the cap of all residue?
Caps are in great shape, except for the O-rings sticking when trying to fuel...
Best regards,
Mike Bauer
Mike Bauer
UTC -09:00 Alaska
Old 08-22-2018, 01:19 AM
rv8or rv8or is offline
Default Chapstick
I use lip salve chapstick, works well.
Rob
Old 08-22-2018, 04:38 AM
DanH's Avatar
DanH DanH is offline
The mystery product is probably EZ Turn or some other brand of fuel lube:
http://www.aircraftspruce.com/catalo...?clickkey=9406
Dismantle the caps, remove all the old lube, re-lube the o-rings sparingly, assemble and readjust the caps. Don't need new o-rings unless they are somehow cracked or damaged.
I like the chapstick idea. EZ Turn is sticky.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-22-2018, 04:50 AM
bobnoffs bobnoffs is offline
scuba shops sell pure silicone grease to be put on o rings.so i am sure you can find it online.fuel doesn't dissolve it.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
snopercod's Avatar
A light coating of DC-4 works for me.
(2019 dues paid)
Old 08-22-2018, 05:16 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Push down
You probabably know this but I picked up a helpful tip here on the forum. With the lock lever flipped up, push it down . Then rotate/lift the cap out. I use EZ turn and this procedure makes it very easy to remove caps.
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 08-22-2018, 05:54 AM
pick your poison, anything is better than nothing. proper adjustment is critical. not to tight, not to loose.
TURBO YES =VAF= Payed Jan2018
Old 08-22-2018, 06:20 AM
burgessbuilderMO13 burgessbuilderMO13 is offline
Default Lube for ring
For 17 years I've used a drop of oil from the dipstick, spread around the o ring then exercise the assembly. You have at least five quarts with you at any time.
Old 08-22-2018, 06:44 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Parker O-ring Lube
I use purpose made Parker O-ring lube (sparingly). I'll look when I get to the hangar and edit this post with the specifics.
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
428 hours and counting . . . .
Now based at Moontown (3M5)
Old 08-22-2018, 06:53 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
EZ Turn is not workable when it is cold out...you may not be able to remove the cap without warming them up. That is the very worst thing to use on fuel caps (unless you live in Alabama, for example...). Take the caps apart and clean as much of that glop off from all the components as you can. It can only be removed by rubbing it off - nothing reasonable will dissolve it. I've used Tri-Flow every few months for 15 years or so, works well. When the caps are adjusted properly, they should require very little force to click the tab down, and should pull up out of the tank very easily also when opened.
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
