It looks like there is an oil leak coming from under the lower hold-down clamp of my right mag (slick). Looks like the oil is seeping through the stud and out from under the hold-down nut. I recently changed oil and adjusted the timing of the right mag. I have not flown since then. After finding the leak on the floor - many drips worth over the course of several days, I cleaned it up, hoping it was just some drips from the recent oil change. Days later the tiny puddle is back. I torqued to 17 ft-lbs after adjusting the timing according to the lycoming manual. Yesterday, I loosened the nut, cleaned up the oil seeps again and re-torqued it. Haven't checked it yet today.
Does it make sense that oil would seep from this spot? I read on the Google that there has been some issues in the past with torque on these hold-down nuts and cracking somewhere. Any suggestions or thoughts?
