What kind of Antenna is this?
steve murray
I found this in the dark recesses of the hangar I rent. Is this a vhf antenna that I could install at my house to listen to airtraffic on my handheld ICom?
The picture is of one antenna on the pole, there are several up & down the pole connected in series... if it is a vhf antenna, could I use just one?
f_w4IJlWyy6FHZq4NL7TgJX-RCsltmKMbKPTUOi4hTngUSajOZvdZ9VITbPSgJgikFbz6tsRb0IOXKuWR6xwgfnbzXl_HgzQfcrFNBaaA6jeIuYenOAX_bxVo9nlEqU8Ip_DfI4QVdALWt4O10ZjLQlVWMK61jLD3WFZPQ7tlFmmllSY0pWCeS6g18js8kVJYIZrxevVv3-8GGo_0T6OWbGT1gKl7wKb452fnnzdlTerJUZi03SvruXBEyr3_RTfZ-lV7Db1XmYu6mNj03pf19XZAdPlG43T8a--X7oohvCBrlHBDJI4IVDJZN1MTV9NC5vCWdGtt50H_rSubR5CkTbE2EPcmaYXBOoKvrhxnjghwQmy1jWIAW1-wERXU-Rs-xRILQFD9_yC972z8g_LZGzUreGj9Yrci28rGyKjS6lUgsANiSYvw4v3bTrSXPvnvQlrfh0E-z45K4x1BCYWCxgo6yWDO4ddE6CuZm0pNTGq3_6GcrlsYCDD_LEiRF8fzk8-IKHRrlA72yqPQ8895dYDgsVHOdGm5GSLAaqM2-uDyycV-TNj9pcSg69u-KCc-6CXjR7Bv2WjGbhQhA0jbqdPXJuw8CSsFHv_4y0=w1379-h1034-no
I doubt that they are actually in series.
FWIW, you can make a serviceable VHF antenna for a ground station using almost anything that you possess that's made of metal, plus a BNC connector. Lots of Kitplanes articles over the years on making them.
I'm going to take a wild, slightly educated guess here.
If you found it in a hangar, and there are several interconnected assemblies like that on a pole, I'm going to guess it's a collinear VHF antenna, probably tuned in the VHF air band. It won't hurt to try using it as-is for receiving; I wouldn't want to use it for transmitting without some additional knowledge or putting it on an antenna analyzer.
