rcarsey
Newer -iS models have power leads going to the headset jacks as part of the standard wiring harness that Stein builds for us.
The KAI mentions this by basically saying hey there?s extra power leads, so if you want to install a 6-pin jack for a Bose-type headset, go for it.
Question for the group is .. should I still wire up the conventional jacks as well? Will it introduce unnecessary noise? Should I just repurpose one of the two jack holes? (the LEMO hole is 14mm with two flat sides of 12mm ? bigger than the existing holes)
