Old 09-28-2019, 11:54 AM
Surfdoc Surfdoc is offline
Default Tank Skin Countersinking
I am sure this has been posted before but couldn't find anything. Where the tank skin attaches to the spar with the #8 screw. Did you dimple the skin or countersink? I dimpled one tank and it looks bad so I was told to countersink the #8 hole instead. I did one but seems like it removed way to much material and there is a lot of play with the screw. Now I do realize that the plate-nut carries the load but I would like to see what others have done.
Thanks in advance.
Old 09-28-2019, 11:56 AM
chaskuss chaskuss is offline
That tank skin is to thin to machine countersink. Use the dimple dies.
Charlie
Old 09-28-2019, 11:58 AM
lr172 lr172 is online now
Not a good idea. As the hole gets bigger, you lose the pilot hole and the cutter will drift. This will create problems when you attach the tank to the wing. If you're committed to this approach, make a backing strip for pilot holes. It will be more secure with dimples though.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 09-28-2019, 12:02 PM
FredMagare FredMagare is offline
Countersink it so that the screw grips the metal of the tank to help hold it in place.
Good luck!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 09-28-2019, 12:25 PM
rmartingt's Avatar
rmartingt rmartingt is offline
My recollection for the -7 spar is you machine countersink the anodized spar flange (where the nutplate is) and then dimple the tank skin. At least, that's what I did. The -9 is probably almost identical in method here.
RV-7ER - finishing kit and systems installation
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 09-28-2019, 02:43 PM
rvbuilder2002's Avatar
Thanks in advance.
Let me guess.... the poor dimples on the first tank were probably done with a hand squeezer?
The fuel tank skin is pretty thick by RV standards, but still no where thick enough to machine countersinking for a screw. The thickness of the skin also takes quite a bit of force to form a nice dimple. Only a hammer with a c-frame tool should be used. If that is what you used, then you just didn’t hit hard enough. If not, you can form the dimples again ( on a finished tank it is useful to have a helper).
BTW, it is not the nutplate that takes the load (In fact in most fastener joints on an RV, the nutplate is never the main load path). The primary load path is the shear load of the dimple within the counter sink of the spar flange. If you machine countersunk all of the holes, the shear strength of all the screw joints would be severely compromised.
It might be good to review section 5 of the construction manual regarding dimpling and machine countersinking.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 09-29-2019, 05:47 AM
Thank to all. I am glad I did not listen to all the "helpers" who came over to the shop and fed that garbage to me.
Old 09-29-2019, 12:15 PM
sblack sblack is offline
Advice is always worth exactly what you pay for it. Buyer beware!
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2020
Instagram @sblack2154
