Old 09-25-2019, 03:54 PM
meloosifah meloosifah is offline
Default RV 7 engine mount question
Good afternoon all,
A quick question for the brain trust - I emailed and called Van’s 3 days ago and haven’t heard back -
I have heard rumor of an engine mount with both the Taildragger and Nosedragger sockets for a -7A / -7. Anyone know if this exists? If so, what is the part number? I have searched my packing lists and “the list” and Vans site to no avail.
Conversely, anyone know of a shop near Indianapolis that could correctly and safely modify this one by adding the correct sockets for a TD to the tricycle mount?
I am hanging and plumbing an engine so this is the time to make the switch, from what I can gather of the work required.
I figured that if I had both on the mount, someone could bolt the main gear receptacles back in and return it to nosedragger status in the future if desired, with minimal effort. Am I crazy?
RV7a - converting to TW and then ready to install the engine and panel.
Old 09-25-2019, 04:13 PM
rvbuilder2002's Avatar
Crazy? No.
Is it practical? For just a maybe situation some day in the future, not in my opinion.
Especially since the tail dragged gear sockets protrude slightly outside of the cowl profile. Who would want a tri gear with tail dragged gear sockets sticking out the aft bottom corners of the cowl?
As far as I am aware, there has never been an official part number for this mount. It was done on a custom order basis.
The only purpose it was originally intended for was people building airplanes to put on floats, that intended to fly as a tri gear during times that the floats were removed (the tail dragged gear sockets are used as float attach points).
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 09-25-2019, 10:23 PM
Thanks for the reply, Scott. I guess I was just thinking that in the future simply bolting the gear assembly back in and removing a few cover plates would result in a fairly easily convertible gear system. Maybe I should just close my eyes and jump full in on the conversion to TW.
Old 09-26-2019, 10:30 AM
von_flyer von_flyer is offline
When I changed from the 7A mount to the 7 mount the engine moved forward about 3/4". I believe it is for CG. The empty CG after the mod was exactly the same as before the mod to taildragger.
John von Linsowe
Michigan
Cessna 140
