Old 10-18-2019, 12:41 PM
Default And
I just read an article on the cies (?) sensors. Need to research but they look really nice...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 10-19-2019, 06:22 AM
Thermos's Avatar
Thermos Thermos is offline
Originally Posted by ssonixx View Post
I can use some help. Has anyone successfully interfaced the Princeton multi-point fuel senders to talk to teh Garmin G3x system?
I might be able to help as I just finished calibrating the Princeton senders on my RV-7. Mine are two-point but the process is similar. Can you tell me which RV you’re building and which capacitive plates/probes you’re using?
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 10-19-2019, 06:38 AM
nilberg nilberg is offline
I also plan to use the Princeton 2 point converters with Vans capacitive plates.
I was unaware of the power issues when using them with GEA 24, do any other builder experience with this combination would be helpful.
Bjorn N - RV 7 in progress
Katy, TX
http://www.mykitlog.com/N741BN
Old 10-19-2019, 10:40 AM
Thermos's Avatar
Bjorn,
That’s exactly the configuration that I have and I had no problems powering the converters from the GEA-24.
I’m not sure which Princeton probes/converters Garmin refers to in the G3x install manual as consuming too much power. I measured the current draw of my 2-point converters and they only draw 8 ma, well below the GEA-24’s limit of 50 ma.
Everything worked as advertised when I calibrated the senders and G3x using Princeton’s and Garmin’s instructions.
HTH
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Old 10-19-2019, 11:04 AM
Default possible...
I spoke with Todd at princeton some time back about this. I think part of the confusion is that princeton makes capacitance SENSORS and they also make a capacitance CONVERTER/INTERFACE.
After speaking with him, it was apparent that the sensors (the black puck with the tube that goes in the tank) does NOT need a converter; it outputs a variable voltage based on the capacitance sensed. This output works just fine with the GEA24.
The CONVERTER/INTERFACE is to be used when you use a home rolled setup, usually with plates in the tank. This black box converts a variable capacitance to a variable voltage to be used with the GEA24, and may require more power than the GEA24 can reliably provide.
I have corresponded with several people that are using the princeton sensors with the GEA24 without any issues...
Look at the probe sensors and converters here:
https://www.princeton-electronics.com
Bob
297 HP Barrett Hung
Wiring...
Old 10-19-2019, 12:01 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Bob,
While it is true that some of the Princeton converters require more power than is available from the highly regulated +12V transducer power outputs on the GEA 24, we have never heard of this being a problem since these converters all seem to be capable of being powered directly from aircraft power.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 10-19-2019, 01:28 PM
Default thanks!
Yes, I guess I wasn't clear.
My point was that the Princeton sensor probes seem to work fine with the G3X system and a converter is not necessary...
Thank you for your input!
Bob
297 HP Barrett Hung
Wiring...
