Okay folks. Hold on. Didn't quite finish with the install past weekend. "Life" got in the way. Mostly done though. Next time down at the hanger I'll take some pix.
There are no gearleg fairings for the main gear, only for the nose gear. There are no intersection fairings at all.
And actually, tar and feathering ain't that bad once you've had it done once or twice.
I go through a lot of screws that way. I wonder if air-locs would work.There is no hole in the main pants for an air chuck. The front portion comes off easy enough, like the other RVs. Takes just a couple muinutes. I've put air chuck holes in wheel pants before. I found it took too much fiddlin' to get them to line up with the valve stem to use. It was almost just as easy to pop the front off.
something like this?
That's exactly what they look like! How'd you get these shots?
(I'll post the pix Saturday)
Okay, now we have a firm commitment!
Did he mean THIS Saturday? Looks like he gave himself an out.
You guys are very welcome. Sorry it took so long.
Okay, I'll be at Sun & Fun.... and thirsty!
Not being an aerodynamicist (sp?), I am going to assume that the round nosegear leg is much draggier than the flattened main gear legs, which have camphered leading edges. Also, I don't think the brake line on the trailing edge offers much drag, if any at all. Krueger would be the best one to answer this.
Those wheel fairings look great - especially the nose gear - looks like quite a lot of 'clearance' from the ground - nice.
I'll want main gear fairings for my 12 but am a long way from that stage. I am sure that someone will offer a kit for fiberglass main gear fairings is Van's doesn't. Should be simple enough - right? That would pretty much make the 12 complete in my minds eye.
As soon as they are painted and installed, I'll post a picture.
Wheel Pants release coming at Sun n Fun? hmmmm Mitch has had his on for awhile now. Problems?
Mitch received pre production prototype parts. Maybe it has something to do with attempting to have parts in stock for at least 25 kits when orders are first excepted.
Multiply that X's 7 different composite parts that are being newly put into production by a vendor... that adds up to 175 individual parts. Plus some other parts that are machined by another vendor, plus.....you get the picture.
I am actually guessing though... I do not personally know what factors made S&F the chosen date.
That looks sharp! Did Mitch happen to mention any performance numbers?
